Can't add iPhone 14 Pro or Pro Max to bluetooth disarming
Tyler, you can add my panel info if you want, no problems with that.
As an update, I was able to finally get my phone paired. I didn’t see your (Tyler) suggestion, but I followed the advice ImpetuousRacer gave on just trying over and over again, and finally it ended up working after about 20 attempts. Wasn’t very fun, but glad it’s finally paired.
Hopefully Qolsys implements a real fix on this soon, for anyone else facing this, and just in case I ever have to re-pair or pair a new phone!
I verified yesterday that iOS 17.4.1 does not fix this problem. The workaround posted still works though.
The problem appears to be related the timing of the iPhone connecting to the panel during the pairing process. I think that’s why the workaround works, or why doing it over and over again eventually works, after so many tries you eventually get lucky with the timing and it works.
Thank you, I have submitted your panel’s IMEI to add to this issue with Qolsys
Thank you for that information. Fortunately the work around seems to resolve but Qolsys representatives have stated that the issue is being looked into as well.
I wanted to chime in that I also had the same problem pairing iPhones (a 15 pro and a 14 pro on iOS 17.4.1). The pairing process would fail.
Using your workaround instructions worked! Though, it would be great if Qolsys ultimately fixed the issue as I’m sure there are countless new users who just give up on automatic disarm via their phone because they could never pair.
