Hey guys if Im looking at adding ADC cameras to my parents home when we install the system but I was reading some place about adding a sd card to allow continuous recording without the Svr can u all explain what the difference is with using the svr
What you are referring to Alarm.com calls, Smart View. More information on how it works, the plan you need and which cameras are currently compatible can be found below:
More information on using the SVR can be found below. Note that the SVR has been discontinued with no replacement. The CSVR126 (Commercial) is still available (although we do not sell it).
So I know there is clips involved with ADC what I can’t seem to find a answer to is say I have a SD card installed does that count towards the clips limit or no ? I just wondering if I want to go the SD route or go for getting a SVR
No, cloud clips have nothing to do with SVR or SD card local recording.
So how would I view the clips from the SD
They are not clips. Onboard storage is for 24/7 recording like the SVR. With a supported plan you’ll see the Onboard 24/7 Timeline tab under the video page in Alarm.com. Playback is through Alarm.com.
Ok I see now
What memory card do I need to get
ADC recommends one of the following officially supported brands:
Micron Industrial Memory cards
SanDisk High Endurance
WD Purple micro SD cards
256gb maximum storage.
I’ll most likely go with the San disk memory card
I know the cameras I’m going with is the New 724 and well the new ADC doorbell I’m just researching the power supply options
And also I will be using the New IQ Panel 4 so I’m very excited
Question about Smart View 24/7, are we able to download footage from the account if needed?
Also before I purchase the sd cards, I have 3 v723 cameras on surety complete I also have the extra camera add on for more clip storage. Would I be able to start using Smart View for those 3 cameras plug n play as is with the services I currently have?
Yes you can export footage
Due to the way Alarm.com lays out the video access, by default the Complete plan supports 2 cameras onboard recording.
However, if you want to use SD card onboard recording for more than 2 we can add that to your plan in place of SVR access.
Yes, the 723 camera is compatible with onboard recording.
Will this cost extra for the extra cameras or no I know once install the 724 cameras I plan on when I find a SVR going back to that so will need to take place once I do or will have to pay for extra SVR service
Currently you can have either of the following with the Complete or Protect plan:
A) SVR + 2 camera onboard storage.
or
B) All cameras onboard storage.
You can go from one to the other if need be.
ok thanks Jason
does the adc vdb770 support sd storage with smartview?
I have a VDB770 for awhile now and I don’t believe you can. It is also not listed in the model of cameras that have that ability.
No, not at this time. Compatible devices are listed here, also linked above. This has been requested though, so I’m hopeful for it in the development pipeline.
