Alarm.com Prism Series 8MP Varifocal Dome Camera (ADC-VC8498PA)
Overview
The Prism Series 8MP Varifocal Dome Camera (ADC-VC8498PA) secures properties day and night. Ultra HD resolution captures every detail, while VividNight™ technology delivers clear color video in low light. Proactive Video Deterrence with two-way audio helps prevent incidents before they escalate. Fully integrated with Alarm.com for Business, the Prism Series Dome provides reliable, high-performance video security.
Features
  • 8MP Ultra HD Resolution
  • VividNight™ Low-light color performance
  • Remotely adjustable varifocal lens
  • Built-in IR up to 40 meters (~131 feet)
  • Integrated Video Analytics
  • Onboard Recording with Smart View
  • Two-Way Audio via external input/output setup
  • Power over Ethernet only
  • Rugged Housing — IP66, IK10, NEMA 4X
Included accessories
  • Camera
  • Mounting hardware
  • Cable gland
  • L-shaped wrench
Optional accessories
  • ADC-VACC-AO-015 accessory cable (required for audio Line-in and Line-out)
Specifications
Max resolution 3840 x 2160 (8MP)
Image sensor 1/1.8 SONY STARVIS 2 CMOS
Field of View Horizontal 110.4° - 45.1°
Field of View Vertical 57.9° - 25.4°
Field of View Diagonal 133.9° - 51.8°
Range of motion Pan: 350° Tilt: 80° Rotation: 350°
Remote varifocal control Focal length, manual focus adjustment, autofocus
Low-light sensitivity 0.02 lux @ F1.6 (Color) <0.005 lux @ F1.6 (B/W) 0 lux with IR on
IR range Up to ~131 feet (40 meters)
Image adjustments Flip, brightness, contrast, saturation, sharpness, exposure
Ethernet connection 10/100 Mbps Ethernet (RJ-45)
Operating temperature IR Off -35 to 60°C (-31 to 140°F)
Operating temperature IR On -35 to 50°C (-31 to 122°F)
Operating humidity Up to 98% RH (non-condensing)
Input voltage IEEE 802.3af type 1 PoE
Power consumption Day - IR off 9.6W
Power consumption Night - IR on 12.4W
Dimensions: (LxWxH) Ø 5.28 x 4.57 (13.4 x 11.6cm)
Weight 2.18 lbs (0.99 kg)
Ingress protection IP66, NEMA 4X
Impact protection IK10
Local Recording SVR and Onboard Recording
Two-Way Audio Full-Duplex with built-in mic. External speaker installation required
External speaker connection Output: 3.5mm Mono Female Connector Input: 3.5mm Mono Female Connector
Note : External audio requires use of the ADC-VACC-AO-015 (sold separately)
Installation
Troubleshooting
