Alarm.com Home Automation
Home Automation Control through Alarm.com
Alarm.com connects all of the key devices in the home, providing smart, responsive automation and seamless control that your customers cannot get from a stand-alone solution. Alarm.com’s intelligent services platform is the foundation for the smart home – allowing for advanced control, better awareness, and reliable, state of the art technology.
With automation you can:
  • Control lights, locks and garage doors
  • Create automatic light schedules
  • Automate lights to turn off when the system is armed or door is closed
  • Ensure the doors are locked even when you aren’t at home
  • Open or close garage doors remotely
  • Use access codes to control and monitor entry into the home
Multi-Sensor Learning
Alarm.com learns activity patterns using data across all of the connected points in the home.
Predictive Performance
Alarm.com uses activity patterns to take the guesswork out of saving energy and money.
Personalization Engine
With the flexible rules engine, Alarm.com lets the user have precise control of the system so that they get exactly what they need.
Location-Based Automation
Alarm.com automatically adjusts the system based on set rules when it detects that the user has left their home Geo-Fence, or when they are approaching it.
What Surety service plans include Home Automation
Home Automation is Included with the Surety Home and Surety Complete Service plans
Compatible Equipment
Home Automation features can be found through Alarm.com with a variety of devices including:
  • Lighting Control
    • Z-Wave
    • PowerG
    • Lutron Integration
  • Lock Control
    • Z-Wave, PowerG, and Schlage Encode Wi-Fi.
  • Thermostat
    • Z-Wave
    • Wi-Fi (Lennox and Google Nest)
  • Garage Opener
    • Z-Wave Linear GD00X and Ecolink
    • LiftMaster Chamberlain myQ ($1 mo/ add-on required)
    • Genie Aladdin and OHD Anywhere Wi-Fi
  • Shade Control
    • Somfy TaHoma Hub
    • iBlinds v3.1 Z-Wave Window Blind Motor
  • Audio
    • Sonos
    • Legrand
  • Water Management
    • Alarm.com Smart Water Valve (SWM150 requires Water Management Plus add-on)
    • Flo by Moen
    • PhynPlus
  • Irrigation Control
    • Ran Bird
    • Rachio
