I have the 2GIG Go!Control Panel with firmware version 1.13. I just added an Aeon Labs Aeotec Z-Wave Smart Energy Monitor Model AEDSB09104ZWUS. How do I clear the history in the Energy area of my control panel to get rid of the old energy readings? It’s also reporting a low battery alarm. I have it plugged in so I don’t have to use batteries. But even with good batteries installed it has the alarm. Any ideas?
I checked to see if Aeon Labs had the latest Home Energy Meter firmware on their website and they only had version 3.64. I don’t know how you guys got the latest version 3.67 but it worked great. Now there are no batteries in the meter and it’s being powered by my electrical panel and I’m not getting any low battery alarms.
Does anyone know if the gen 2 of the Aeon energy monitor (AL-DSB28-ZWUS Z-Wave Home Energy Meter) is compatible with the Qolsys IQ panel? If not, is the gen 1 compatible?
wondering if this is still true. I would like to get one of these Home Energy Monitors by Aeotec with my IQ2 panel. Alarm.com lists the Gen 2 device on their website. Does this mean it will work/be compatible with the IQ2 panel?
Also, I have energy monitoring usage on my account via my Sump Pump Aeotec HDS switch. If I added the above home energy monitoring device, would it simply just appear under my sump pump in this card? Does energy monitoring appear on the panel or just adc.com app/website? thanks
Since then Qolsys has listed compatibility with the ZW095-A (the Gen5 version) as well.
The list on Alarm.com is usually a good list to follow, but it specifically references devices that are tested compatible with Alarm.com-manufactured Z-wave radios (the ones in SEM, and Interlogix panels for example)
The Qolsys panel list is typically a better one to go off of for the IQ Panel 2 specifically.
No, it is not found with the water management sump pump monitoring card. Home energy monitoring details would show up under the Activity page in Alarm.com, under a new Energy tab.
Just got the Gen5 ZW095-A meter today and without actually installing it in my electrical panel, I wanted to see if it integrated properly. Added it through the z-wave network on my iq2 panel and it showed up as “energy clamp” with no options other then custom name. No problem, it listed as a zwave device on my panel. However when I log in to my adc.com app, click on “Energy Usage Data”, just my sump pump energy monitor show up. Am I missing a step?
Z-wave devices in general might have a delay in when the panel reports those devices to ADC and syncs the device details. Surety users can send a command to sync their panel device list with Alarm.com via the Surety System Manager.
If you do not use Surety as your service provider please be sure to contact your provider for assistance with updating your equipment list in Alarm.com.
