The keypad doesn’t determine whether the panel is compatible with the Alarm.com SEM, the version of the PROM chip does. Are you able to see the version printed on it as shown here?
If your panel is compatible with the SEM then we recommend getting a full-alpha keypad for the panel to make programming it easier but it’s not required. You can use the non-alpha keypad if you want.
