ADC-VDB770 camera reboot
HI,
Question.
I have this camera for a couple of months. Does the camera should automatic rebooting and connecting after a power failure? If no, it’s a big gap when we are away from home.
Thanks.
Yes, any time the power is lost and regained, it would reconnect to the saved network. This will of course require the router to also regain power and boot back up. It usually takes the modem the longest period of time to boot back up and reconnect. Some modern modems can take upward of 5-10 minutes.
Thanks for the follow-up.
I understand the camera will re reconnected after a delay. But after many hours it still not reconnecting. Flashing green or go to red.
Something I have to adjust? All my others devices reconnect without any problem.
Thanks.
You may need to power cycle the camera to get it to reconnect to the network
In general, the VDB770 will relay the mode it is in, or issue it is experiencing, via the onboard LED:
