When your schedule has an “override” event, do not use remote interactive to change hold or set temps.
I am going to try to recreate this.
So you are saying that using the app to manually adjust the target temp during an override (does it matter if it is “Away” “Sensor left open” etc.?) causes the thermostat schedule to continue making changes at the appropriate times but not to the appropriate temps?
I see the above post I quoted has changed. And yes, we’ve looked into this with regard to the thermostat “learning” the change, but as far as I understand it this should not be occurring and is not a feature.
So, as an example: Target for schedule is 8am 75 degrees, 8pm, 78 degrees. at 6pm an away override changes it to 80 degrees. So the next 8am change will be 80 degrees?
Is it not that obvious or direct of a change?
I’m looking for an expected pattern of how the Tstat will behave.
We’ll do some extended testing and try to replicate what you are seeing then.
Will be manually adjusting the Tstat to a temp that could not be the result of schedule temps and/or other overrides. Is a week sufficient to likely see an error based on what you saw?
From my experience, the 7th day was the magic number for it to learn your preference, and then all bets were off as it would deviate from schedules, etc.
Hi all, was this issue ever resolved? I currently have 2 of these tstats and cannot get the schedules to stick. We are on a time of use electric plan so a programmable thermostat is a necessity. I am about to just switch back to my $25 honeywells if this can’t be fixed.
We’ve not been able to replicate. Is this in reference to a suretyDIY account? If not, your dealer may be able to provide some more detailed info regarding your Z-wave network communication quality.
However, happy to help if we can. What is the firmware version on your ADC T2000s? You can find this by holding the up arrow while the Tstat is set to “off” for its mode. There will be two versions.
I apologize I don’t have a suretyDIY account but I appreciate the follow up. My network seems to be working fine because all of my other devices work properly. I just got done removing both tstats and relearning them so I will see if that helps.
No apologies needed, just want to make sure. There are some diagnostics we wouldn’t have access to in this case.
Were your Tstats originally learned in on battery power? Keep in mind they will only function out of FLiRS mode if learned in while connected to AC.
FLiRS can cause some command and status recognition issues, and I generally don’t recommend using it since the Tstats don’t function as repeaters that way.
I don’t have any unused wires and have a C wire hooked into the thermostat but it appears to be running on battery only. I believe the previous thermostats were the same.
The schedule seems to be working now after the relearn so i will see how long that lasts. I haven’t manually changed the temp yet to see if it will switch back to the schedule. That seems to be the issue. Thank you for your help.
Sounds like the C wire may not be connected at the HVAC. This can be checked if you wish to use AC power.
Well, that was short-lived. After one manual change to the thermostats they no longer adhere to the schedule. I also have 2 remote temp sensors and they won’t stay selected for temperature averaging. In other words, they are recognized by the system and I am able to select them to temp average with a thermostat but next time i login, it is no longer paired with that thermostat. This is extremely frustrating, really wish I would have just bought Nest thermostats.
On my home screen there is a “Security” button and a “Services” button below it.
I relearned both thermostats again but this time I did not add the 2 temperature sensors to the system and the schedules have been working fine so that seems to be the issue. I have changed the temp manually and it goes back to the schedule at the next set point. I guess I will forego using the temp sensors for now until I hear of a solution.
I mean under the physical emergency button. If you have the word emergency spelled out, the RTS will not be compatible as that is an older model Go!Control with older Z-wave radio version that does not support the RTS.
