2GIG IRF motion detector
How do I put passive IRF motion into learning mode or how to install it to a 2GIG edge panel
Steps on how to pair a 2GIG PIR1-345 Motion Sensor with a 2GIG Edge alarm panel can be found via the below guide:
Once the panel is in learn mode, you can trigger the sensor to pair it. Make sure the Sensor ID on the Motion matches what is populated in programming.
