2GIG Edge Panel Sensor Programming
How to access the sensor programming section
To begin from the Edge panel click on:
  • Settings Gear Icon
  • Use Face Recognition or enter the Installer Code (default 1561)
  • Click on Installer Toolbox
  • Click on Panel Programming
  • Click on the programming section associated with the device being programming (ex. Wireless Zones)
2GIG-DW10-345 Thin Door/Window Contact, Programmed for an Entry Door
  • Sensor Type: 01 - Exit Entry 1
  • Equipment Code: (0862) 2GIG Thin Door/Window Contact
  • Serial Number: Learn - Trip Sensor
  • Equipment Age: New
  • Sensor Loop: 2
  • Transmission Delay: Disabled
  • Voice Descriptor: As Desired
  • Sensor Reports: Enabled
  • Sensor Supervised: Enabled
  • Sensor Chime: As desired
2GIG-DW10-345 Thin Door/Window Contact, Programmed for a Window
  • Sensor Type: 03 - Perimeter
  • Sensor Loop: 2
2GIG-DW10-345 Thin Door/Window Contact, Programmed for a Wired Input
  • Sensor Type: Based on the wired sensor type used
  • Sensor Loop: 1
2GIG-DW20R-345 Recessed Door Contact
  • Equipment Code: (0863) 2GIG Recessed Door Contact
  • Sensor Loop: 1
2GIG-PIR1-345 Motion Detector
  • Sensor Type: 04 - Interior Follower
  • Equipment Type: Motion
  • Equipment Code: (0869) 2GIG PIR Motion Detector
  • Sensor Loop: 1
  • Sensor Chime: Disabled
2GIG-GB1-345 Glass Break Detector
  • Equipment Type: Contact
  • Equipment Code: (0864) 2GIG Glass Break Detector
  • Sensor Loop: 1
  • Sensor Chime: As Desired
2GIG-SMKT3-345, 2GIG-SMKT8-345 Smoke/Heat/Freeze Detector
  • Sensor Type: 09 - 24 Hour Fire
  • Equipment Code: (1058) 2GIG Smoke Detector
  • Serial Number: Learn - Tamper Sensor
  • Sensor Loop: 1
  • Voice Descriptor: Smoke Detector
  • Sensor Loop: 2
  • Voice Descriptor: Heat Detector
  • Sensor Type: 08 - 24 Hour Auxiliary Alarm
  • Equipment Type: Freeze
  • Sensor Loop: 3
  • Voice Descriptor: Freeze Detector
2GIG-CO3-345/CO8-345 Carbon Monoxide Detector
  • Sensor Type: 14 - 24 Hour Carbon Monoxide
  • Equipment Code: (1026) 2GIG CO Detector
  • Sensor Loop: 1
  • Voice Descriptor: Carbon Monoxide Detector
How to Delete a sensor from programming
  • Select the Zone you wish to remove and choose Reset Zone
Learn E+ Sensors with Multiple Loops
The E+ Door/Window sensors and the E+ Smoke Detector have multiple loops.
If one of these sensor has been programmed, the additional loops are available
to add to a zone without an additional learn/pairing. Follow the steps below to
configure the additional loops (Door Window - Wired Loop and Smoke Heat and
Freeze Loops).
  1. Enter programming and select the zone you have
  2. Tap on the loop name(Wired) on the bottom of the screen
  3. Tap and highlight one of the available zones on the left side of the screen
  4. Tap Assign to go to the setup process.
  5. Select the sensor type
  6. Adjust remaining options as needed
  7. Delete the reed zone if not needed
