1080P Indoor/Outdoor Varifocal Dome Camera ADC-VC847PF
Features
  • Power over Ethernet
  • IR night vision
  • Onboard Recording with Smart View
  • Video Analytics with Object Detection
  • 1080p WDR and HDR video
  • IP66-rated waterproof & dust-tight
Included accessories
  • Camera
  • Dark Gray Cover
  • Mounting hardware
  • Torx wrench
  • Water-resistant cap
  • Cloth
Specifications
Supported resolutions 1920x1080, 1280x720, 640x360
Local recording Select microSD cards*
Image sensor 1/2.7" Progressive Scan CMOS
Lens 3.2 mm(W) - 9.8 mm(T), F1.8 - F3.3
Field of view 34° to 116°
Iris P-iris
Remote varifocal control Focal length, Manual focus adjustment, Autofocus
Angle adjustment Pan: 0° to 350°; Tilt: 0° to 55°; Rotation: 0° to 180°
Low-light sensitivity 0 lux with IR
IR range Up to ~95 feet (30 meters)
Image adjustments Flip, brightness, contrast, saturation, sharpness, exposure
Ethernet connection 10/100 Mbps RJ-45
Operating temperature -22°F to 122°F (-30°C to 50°C)
Operating humidity 20% - 100% non-condensing RH
Power 12 VDC ± 10% or PoE (802.3af), 10 W
Dimensions (WxH) 4.7 x 3.9” (119.3 x 99.5 mm)
Weight 594.5 g
Ingress protection IP66
Impact protection: IK10
Planned compliance: FCC, IC, C-Tick, CE Class B, UL
LED Guide
LED pattern Description
Not illuminated Power off
Solid green Connected to Alarm.com
Blinking green Local network connection
Blinking green and red Reverting to factory default settings
Blinking red Power on, camera booting
Solid red No local or Internet connection
Troubleshooting
