Looking to add outlet to my 2 gig go control. My question is would this require 900mhz? I still have the factory 345mhz. I plan on installing a lom-15. Hope this is the right place to post.
If you are referring to the XCVR2, it requires neither for a Z-wave device. The Z-wave radio is separate and built into the 2GIG Panel.
The 900mhz XCVR2 is used with the TS1, Go!Bridge, and Image Sensor.
Thanks I’ll give it a try without xcvr2
