I installed Schlage F599 with GC3 (3.0.2). Hooked it up with alarm.com:
assigned user codes
set up lock/unlock notifications
Whenever I lock / unlock the lock with the alarm.com app I can see notifications (via alarm.com).
However whenever someone locks / unlocks the lock from the lock’s pad no notifications are fired. Which would be the most useful, as I need to know who opened it (different users have different assigned codes).
However whenever someone locks / unlocks the lock from the lock’s pad no notifications are fired. Which would be the most useful, as I need to know _who_ opened it (different users have different assigned codes).
Am I missing something?
A similar issue existed previously with the GC2 and the Qolsys IQ and this particular lock model, so it is possible this is a software fix, but have you tried any standard troubleshooting like removing and recreating that notification?
Do you ever see individual names associated with the unlock events in Alarm.com history? Try using one of your user codes with lock access to unlock. Does the Alarm.com history show “Unlocked by [username]” or just “Unlocked?”
opening a lock with my personal code vs. other users’ codes
results:
alarm.com history shows nothing if the code is entered from the lock pad (my code or any other working code)
alarm.com history shows “lock unlocked” / “lock locked” without a username associated to these events whenever the lock is locked/unlocked from the alarm.com app / website
You could try removal and re-learning of the lock just to be certain.
Based on previous reports with Schlage locks, it looks like the GC3 may be experiencing the same issue and needs a similar remedy. I’ve already escalated this to ADC to get the wheels moving. It should be pretty easy to diagnose if it is the same.
