The neighborhood had a power failure today and the ZWave devices will not re-connect to panel. Devices that will connect will not stay consistently connected. Does anyone have this happened?
I am showing several Z-Wave devices reporting a Malfunction, indicating they are having trouble communicating with the panel.
Steps on how to resolve a malfunction can be found here
To resolve, try the following:
- Verify the device is powered on
- Activate the Z-Wave device locally to get it to communicate with the panel.
- Run a Z-Wave Network Rediscovery
- Should those not resolve the issue, you may need to Remove/Clear the Z-Wave device from the panel’s network, then Add/Pair it back with the network. After doing this for all devices, run a Z-Wave Network Rediscovery.
