Zones Wiring - Switching from Resolution Products RE108 to Qolsys IQ 4
Hi, I’m newbee to Surety. I’m switching my current Resolution Products RE108 security panel to Qolsys Power G. I need help to confirm if zones wiring done to the Power G is correct.
Existing RE108 panel was using EOL resistors stated as 4.7K ohm per manual. I’m using same EOL resistors with Power G.
I have connected resistors ends of two zones as common during wiring.
Pictures attached old vs new for reference.
Based on both images, yes it looks like that is set up properly. You should be fine with those resistors.
