I’m in the process of taking over a former Vivint system by replacing their 2.0 Sky panel with a first generation panel.
I’ve gotten all my door and glassbreak sensors into the new panel, but when I try to add Z-wave devices it can’t seem to find them (Kwikset deadbolt, CT-100 thermostats). Ideas?
The devices are most likely still attached to the previous Z-wave network. Z-wave devices can only belong to one network at a time. Thankfully, it’s easy to remove them from other networks from the 2GIG panel.
- Services
- Z-Wave
- The little wrench in the corner. (You will need your installer code)
- Remove Devices
- Perform the steps to “learn” the device into the control panel.
- You should see a message pop up on the screen that says “A device has been removed from another network.”
- Once all of your Z-Wave devices are removed from the old network, you will be able to add them to the new network you’re setting up.
- After you’ve added all the devices to the new network, run a Network Rediscovery.
Thank you Jay. Just for clarification, I’m doing this from the new panel, yes?
Yes. All can be done from the new panel.
