Are these Z-Wave plug-in Outlets compatible with Alarm.com where as you can access the units’s menu to control it? Are there any other Z-wave plug-in Outlets that you would recommend?
#2 is commonly used on systems and can be found on the Alarm.com hardware page here. Use this page as an overall confirmed compatibility guide.
We’ve not used 1 or 3. Light switches and appliance modules are fairly simplistic and typically are compatible.
I’m not certain what exact settings you are referring to, but you cannot edit internal device parameters with any Alarm.com system. The devices would operate on default parameters.
