Ok, so the first time I did this with Mud Room Door, it saved successfully, but when I re-checked it, it had re-associated with the panel (or never fully accepted the removal, despite successful messaging). It was only the second or third I tried this that it actually accepted this, and I exited/rechecked a couple of times before my earlier post. I was second-guessing myself, but I’m sure that I performed the same steps in the same way. It was definitely fully unassociated at the end of my initial sequence of actions.
After 30+ minutes, I just rechecked again, starting all the way from the main home screen, and it is still fully-unassociated. The screen for Mud Room Door that shows LifeLine indicates “0 nodes in group”. If I then click on Edit and review the full list, nothing is checked.
I then completed the exact same sequence with Front Door. It also claimed successful unassociation the first time I tried, but it was only on the 3rd time that it actually took, subsequently indicating “0 nodes in group”, and with a subsequent review of the full list confirming that nothing is checked. Functionally, it too is now accepting Lock/Unlock commands in a consistent and responsive manner, just as I was used to with both locks prior to associating the HEM and subsequent Z-wave SDK upgrade/clear/relearn everything.
By the way, I just noticed that with this no-associations configuration that, while Lock/Unlock commands work great, and while Locked/Unlocked status indication also works fine, this correct indication is specifically limited to when Lock/Unlock commands are issued. In other words, if I issue Lock/Unlock commands, the actuation of the lock is successful and the status indication correctly reflects the current state of the lock. However, if I were to manually lock or unlock the lock, and then manually refresh the Locks screen, this status no longer indicates correctly. I gather that this probably isn’t surprising, since we’ve essentially forced a bad configuration.
I have not tried manually associating with some other repeating node. I wonder if rebooting the panel and/or locks may reforce the association back to the panel, like you were saying (haven’t tried this, either, but can if you’d like).
