Are there fan controls that integrate with 2GIG GC2 yet? Something that will control speed of fan, on off of fan as well as light in fan?
If not, anything on the horizon?
The Leviton Vizia RF fan control has worked with GC2 as long as I can remember, but it is just for fan and fan speed control, it doesn’t control lights separately.
If the fan uses two wires with a single hot wire delivering power to the fan, you can’t control a light and fan blades independently via the wired switch that way.
If the fan is controlled via 3 wires with an independent hot wire for lights you could use a separate Z-wave dimmer/switch for control of the lights.
