Is there a list of brands and models that are compatible with my system?
Thanks!
This list here is a tested as compatible guide from 2GIG. Keep in mind that these would be tested as compatible with specific firmware as noted in the list.
This list here is a guide for the Alarm.com ecosystem.
While the lists are largely the same, its a good idea to find a lock that best suits your needs that is on both lists.
You can also check out the August Smart Lock Pro (3rd Gen) and the Kwikset Convert if you only want to change the interior of your lock system - Both are compatible with 2Gig.
