Wired and Interconnected Smoke / CO Detectors
I have several wired and interconnected smoke / CO detectors that are nearing EOL and starting to false alarm. Are there replacements i could install that would integrate with my alarm.com system?
I also have 2 wireless smoke / CO detectors already integrated with Alarm.com, but they are also approaching EOL, so hoping to find a wired solution that could replace everything.
It looks like you are using Concord 4 panel, is that correct? Are those wired smoke detectors AC powered?
The house line voltage interconnected smoke detectors, if that is what you have, would need to be replaced with other AC interconnected smoke detectors required by code.
There are no AC models that directly communicate with the panel, but there is a Firefighter audio detector that monitors that whole circuit of wired smoke detectors:
It is just mounted by one of the smoke detectors and since they are interconnected, when any go off, the Firefighter alerts the panel.
Are those wireless ones installed over locations where AC smoke detectors were removed?
my panel is the concord 4.
the current ac interconnected units are completely separate from the alarm system.
Our house was built in 2018 so we have ac units on every floor and in each bedroom.
We added 2 wireless units that connect to the alarm system but they do not react the ac units. One wireless unit is in the basement and one is on the second floor. Each one is located next to an AC device.
i will just find suitable replacement ac devices. And consider that add on box to connect to the alarm system when my current wireless device age out.
Since you have a Concord if you’re handy many companies make relays that allow you to hardwire your existing AC Smoke and CO detectors into your alarm. I have Kidde AC smoke/co detectors and I use the Kidde SM120x and a CO120x to hardwire the system into my alarm panel. Very easy to accomplish and you get the added benefit if they are communicating detectors that the entire house is protected.
Thanks @TxAg07, that’s an interesting idea. I’ll have to see if I have an available connection to wire something like that into my panel.
