Windows Entry Delay sensors
When I was testing the system, when the motion detector or the windows were opened during ARM AWAY, there is an entry delay time.
How can i set it up so that when the alarms are armed during ARM AWAY, only the Front door and Garage doors have an entry delay and the other sensors should trigger the alarm immediately?
It looks like your sensors are learned in as Group type 10 - entry-exit normal delay
To change this, enter programming by swiping down from the main page > Settings > Advanced Settings > Installer(default1111)/Dealer(Default2222) Code > Installation > Devices > Security Sensors > Edit Sensor > Press the pencil on the zone you want to edit > Change sensor group to 13-Instant Perimeter D/W
Group type 13 will make the door/window instant alarm when opened in either away or stay
Motions are normally programmed as group type 17
Let us know if you have any other questions
that works
thank you
