I have message that a Qolsys-2 “Easy Panel Update” is required. However, “It looks like the Wi-Fi on your security panel isn’t enabled.” It actually IS enabled, but after detecting the network name and typing in the correct password, the
I should also point out that the Wi-Fi network includes a dash and number, as in abcdef-4. Not sure that would make a difference. Also, when i attempt to connect, at first it seems that the connection would be made, but it never really is.
According to the IQ-Panel, wif-fi is enabled. But according to the email received today regarding an update, it is not enabled.
I’d do the update manually from the panel, but that does not appear to be an option. Please advise.
What this means is that the panel can connect on the LAN, but it has no access to the internet. This is possibly an issue with the network, or software issue.
Reboot your router and modem. If the connection does not restore after a power cycle of both the modem and router, then software update needed.
On the IQ Panel 2, software can be updated by SD card as an option if wifi is currently down. Instructions from the manufacturer are below:
UPDATE IQ PANEL 2 SOFTWARE VIA SD CARD
If you are not able to update your panel’s software using the Wi-Fi connection, follow the steps below to use an SD card:
Compatibility Note: Your IQ Panel must be on software version 2.0.1 or higher and connected to Wi-Fi to install this update wirelessly. Panels running 2.5.0 & 2.5.1 must be updated to 2.5.3 before they can be updated to 2.8.1
1- Insert a micro SD card into your computer. *(We recommend using a “class 4” or higher micro SDHC card with 4gb-16gb storage space)
2- Click the download link below (we recommend saving it to your desktop)
Right click this file and select “Unzip” or “Open”
You should see a folder with three (3) files inside: “2.8.1rc9.20231026_b9_full_upgrade.zip” “release.txt” and “signature”
Drag ALL THREE files to your SD card. These are the ONLY files you’ll need, so delete ANY other files
Safely remove the SD card from your computer
4- Slide your micro SD card into the slot on the right side of the IQ Panel.
5- Swipe down from the top of the screen and touch “Settings”
6- Touch “Advanced Settings” and enter a valid installer code (default is 1111)
7- Touch “Upgrade Software”
8- Touch “Upgrade Using SD Card”
9- The panel will search the SD Card for the patch and begin downloading it automatically.
10- Once complete touch “OK” to reboot the panel. DO NOT TOUCH THE SCREEN. The update process will take approximately 5 minutes. After the panel reboots the home screen will appear and the LED will turn green.
11- Eject the SD Card:
Touch “SD Card”
Touch “Unmount SD card”
Remove the SD Card from the side slot by pushing it in slightly, it should then “spring” back out
