You answered this awhile back for me, but I forgot the answer and can’t find the response. How can I tell what cellular module I currently have for each of my accounts, ATT or Verizon, via the software, without having to open the panel?
That’s not readily available in the panel UI for 2GIG, inspecting the physical module is the easiest way, checking that model number.
If the module is unregistered our check tool will be able to tell you the carrier.
For active accounts we can just tell you as well. I’m sending a private message to you with that info.
Thanks Jason
