Way to control Duplex Receptacle?
I have some of these GE Duplex Receptacles in my house with lights plugged into them. Is there a way I can control these from within my house (without having to go to the panel every time or use the app)? Like can I set up a light switch of sorts in that room that can send a signal to turn the receptacle on and off?
http://www.amazon.com/GE-Wireless-Lighting-Control-Receptacle/dp/B0013V1SRY/ref=sr_1_20?ie=UTF8&qid=1421444609&sr=8-20&keywords=zwave+switch
I believe that might be directly possible if there is a compatible “transmitter” switch. (These are how 3-way switches are commonly handled with Zwave lighting products.) One switch is essentially a powered dummy switch which is wirelessly associated with the second, Zwave enabled switch.
Another option which would not require use of an AC line, would be to slap a DW10 Door/Window programmed as a non-reporting sensor contact in a gang box, wire its loop 1 hardwired input to a $0.99 toggle switch, and create an automation rule which turns on and off the Zwave outlet based on that sensor’s status. (I do this at my own home with a downstairs light and a rigged switch in my bedroom. Costs about 30 dollars and as many minutes)
If you wanted to get fancy with a second Zwave controller like a Vera, the options expand.
so if i was to get a switch like this:
http://store.homeseer.com/store/GE-12723-Z-Wave-Add-On-Auxiliary-Switch-P1896.aspx?gclid=Cj0KEQiAiuOlBRCU-8D6idaPz_UBEiQAzTagNCXNUXpTiqwshAXhE-T1ov4v-VtWjQb1811MryhAFAwaAoHG8P8HAQ
i could somehow program it to control the receptacle?
The receptacle you linked to is a 12721 while the add-on switch says “The Jasco Z-Wave Auxiliary switch is for use with model numbers 12722, 12724, 12730.” I’m not saying it won’t work but I would check on that first. I have only used the Evolve/Linear 3-way Z-Wave switches that work wirelessly like this so I don’t have first hand experience doing it with a GE add-on auxiliary switch.
