I recently had a water sensor trigger a burglary alarm. How can I fix this so I do not experience false alarms?
Happy to assist!
It would appear that your water sensor has the incorrect sensor equipment type set up. The Sensor equipment type should be set to Water, it currently appears to be Contact.
To change this, start at the home screen of your panel and click on System Settings -> enter Installer Code-> Installer Toolbox -> System Configuration -> Wireless Zones -> Scroll to the Sensor in question and click Edit -> Select Sensor Equipment Code Water. When done making changes click Return to System Configuration and click the back arrow and finally click Save.
Whoops, I should’ve read the instructions closer. Done. Thanks!
