I tried the installer code; it doesn’t work. I wonder if Vivint changed it–I know I’ve seen it on the internet before, so it’s probably not as secret as they’d like it to be anymore.
I’ll take some photos of the guts as soon as I figure out how to pop it open.
Looks like a lot of hearsay on this topic. I think it would be highly unlikely for Vivint to manufacture their own panel in such a way that another company could just step in and monitor it. That was possible with the Go! Control panel because they didn’t do their own hardware, they just put special firmware on the standard 2GIG panel. Even then they did everything in their power to prevent others from monitoring it. They made the firmware so it only worked for them. They had slightly modified cell modules made that only worked for them. It seems likely that given control over the panel hardware manufacturing they would make it so no one else can monitor their panel. No matter what anyone hears or guesses, until someone actually tests it you can’t make any assumptions.
I agree that if an Alarm.com camera worked with the system then it’s probably still using the Alarm.com back end. During the short period when your system was actually working, did you happen to try logging into your account directly on the Alarm.com website? Or did you only log in via the Vivint website?
Ryan it has a telit embedded cellular module for M2M (Motorola) networks. Its definitely not gonna work with ADC. The ADC cams like you said, are separate from panel, and WiFi (so may be using the ADC back end for video)
There is no way to take over the Go2.0 unless your a dealer for Telit M2M. Dunno about POTS/wifi options…but that means getting access to programming…and hoping lockouts are not enabled. In any event, its unknown if Vivint can brick it remotely, so disabling its ability to communicate is recommended.
David, If you keep it, option is to remove module if possible and go local. The cellular module is also GPS enabled. Vivint can see the location and track it.
“Job description
Vivint is looking for an Embedded Software Engineer with expertise in machine-to-machine (M2M) cellular applications encompassing voice and data communications.
Work Location:
The primary work location will be Vivint’s Thanksgiving Point office located at 2500 West Executive Parkway Suite 300, Lehi, Utah, 84043. Frequent business meetings will also be required at Vivint’s corporate headquarters in Provo and at other Vivint business locations.
Desired Skills and Experience:
Typically requires a BSEE and 5+ years of experience or an MSEE and 3+ years of experience.
Strong technical knowledge and experience with M2M application development covering network management and voice and data communications on CDMA and/or UMTS networks is required.
Experience with GSM and/or LTE networks is a plus.
Experience interfacing with Novatel/Enfora, Telit, and/or u-blox cellular radio modules is a plus.”
Its basically like if someone bought your home with the panel already there. Vivint comes out, sets it up/programs it. Only new customers get the sky panel an old/existing customer will never get the sky panel, and one may buy it and then all they need do is have the module replaced or so, or have it remotely reconfigured for their AR/account by Vivint tech support.
Sell it as used “2GIG Go2.0/Vivint Sky Panel” $250…(if it doesn’t sell, lower price)
In description state, "Upgraded Vivint Sky Panel. Requires existing/new Vivint service. Cannot be used with anyone else. Panel functional, working, no returns. As is. If you are an existing Vivint customer, and want to upgrade to the next generation panel, Here is your chance, this is what you are looking for.
Note this requires Vivint reprogramming to your account, and is your responsibility."
