Vivint sky panel adc camera
I wanted to know if my vivint skypanel adc camera will work with my go control panel, I know an adc camera is not compatible with a sky panel , but will it work the other way around? Not sure if this has been answered already:) but please let me know
The cameras would not communicate with the Go!Control Panel directly. They communicate directly with Alarm.com. It would not be directly compatible as different back-end service is used and cameras used with Alarm.com cloud video would require Alarm.com firmware.
wanted to know if my vivint skypanel adc camera will work...
This would be incorrect. It is possible. since the firmware may be an ADC variant. For example, my Skypanel V520IR ran firmware IP8136W-ALAM-0100m2 (whereas ADC used IP8136W-ALAM-0100e)
I have taken a Vivint Skypanel camera, and it is currently on my ADC account (and even though it has nothing to do with ADC cloud cameras, I also have a 2GIG panel).
If you have the ADC Camera (e.g., V520IR), you will though need to have the firmware updated once you manually add it. You will not be able to add the camera normally, add via MAC instead.
see: ADC520-IR Setup Problem - Support - Surety Support Forum
I have taken a Vivint Skypanel ADC camera, and it is currently on my ADC account (and even though it has nothing to do with ADC cloud cameras, I also have a 2GIG panel).
We would not be familiar with all the models used by other services (doorbell cam for example), however, yes if it is based on an Alarm.com compatible model, you may be in luck.
OP states they have an ADC (Alarm.Com) camera.
wanted to know if my vivint skypanel adc camera will work…
