I purchased a 2 gig panel vivint branded off e-bay when I plugged it it it worked ie the touchscreen responded , I was able to access programming with 2203 . I then disconnected , mind you there was no battery connected. I now power up everything is fine except the touchscreen no longer responds??? Is there a remedy to this issue? If possible
Thank You
