Using Older GE Equipment
We have a GE Simon XT panel that wirelessly connects with approximately 18 window sensors and 2 wireless smoke detectors. Presently we are with Monitronics, but are making a move to something else.
I would like to see if it is possible to re-use some or all of our existing components.
  1. Can your company monitor this existing hardware?
  2. We would also like to incorporate 2-4 cameras, what do you suggest? Can you system support cameras?
Our panel has the following information in it : FW X188 Vz
Of course. For general info, this page explains how our service works.
The steps for getting started with a Simon XT are identical to the XTi, as they use the same communication modules. You can see the steps here.
X188 Vz
That would be a CDMA module which yes, typically could be used at this time if it is unregistered. You can check the module communication ID here to be sure.
As an Alarm.com dealer, we provide Alarm.com Cloud Video service. Cloud Video is an optional add-on to accounts. You can find details on pricing at the bottom of this page.
Compatible camera models are listed here.
