I’ve been thinking about the 2GIG-TILT1-345 Tilt sensor and it seems that its application is intended for a garage door.
I’ve been trying to think of a reason why I’d want to use one of these because even if I use it as an entry/exit 2 I would not want to have a time limit to get the system disarmed just because I opened the garage door.
I did have a thought about using it as a “door left open” type of sensor.
Is it possible to program this sensor so it would not trigger an alarm, but, trigger an alert message if a “door left open” condition remained for a set period of time after the system was armed? I’d be interested in setting a condition of say if the door is open more than 5 minutes after the system is armed it would send an alert.
It might be useful in this case to be able to send a command to close the garage door too. I have a Ring Doorbell so if there was a question of whether or not I should send a close command I could check the Ring Doorbell.
