Upgrading GC2 to Edge
I have an old 2GIG GoControl GC2 alarm panel that I would like to replace. It is registered connected to Surety/Alarm.com but recently stopped communicating and is generally showing it’s age. It has connected to it a TAKE-345 takeover module with two hard wired door sensors, two hard wired motion sensors and a hard wired glass break sensor. It also has a CT100 ZWave thermostat. I would like upgrade the panel to something newer while also keeping as many of the devices as possible. My research has pointed me to the 2GIG Edge, Qolsys IQ Panel 2+, and Qolsys IQ Panel 4.
I found a new-in-box 2GIG Edge for $250 that I think should be compatible with my existing devices. If I buy this, what would be the procedure for transitioning to the new panel? Would it basically be this:
  1. Record the zone information for the TAKE-345 devices from the old panel.
  2. Power down and remove the old panel.
  3. Install the new panel.
  4. Provide the new IMEI to Surety with the Swap Cellular Modem link
  5. Re-setup the TAKE-345 to keep the zone information as it was with the old panel
  6. Re-setup all my wireless devices like the panic buttons, smoke detectors and remote arm/disarm devices.
Will I need to set up pin numbers and users again or will that come down when the alarm.com connection is transferred? Are there any holes in my plan? Is 2GIG a dead-end device/company or is there a reason to move to Qolsys?
Thanks for any feedback.
All three panels are compatible with Surety however the IQ Panel 2+ has been discontinued and the IQ Panel 4 would be the newer generation.
This is one option of doing it. The easier way would be to restore the sensors and user codes via a backup. There is currently a backup on your account from January 26th that can be used to restore the sensors and user codes. The 2GIG EDGE panel will need to be on firmware 1.3+ in order to restore the backup.
Ahh I’m glad I can restore to the Edge from the GC2 now as I didn’t think that was available. I went ahead and ordered it. I see the latest firmware here. I will upgrade it according to those instructions, then I should send a PM to support with the IMEI, and the panel will be activated and backups sent down.
Will I be able to backup/restore Z-Wave devices as well? Also - does this panel require being the primary Z-Wave controller? I want to integrate it with my Home Assistant install.
Thanks again.
The backup is only for security sensors and codes for arming/disarming
Z-Wave Devices will need to be deleted then learned in manually.
Yes, the panel does require its Z-wave receiver to be the primary controller
I should be receiving my new EDGE panel this evening. Once I update the firmware to 1.3, how late in the day will I be able to send that PM with the IMEI ? If not today, what days/hours will I be able to do so?
Our hours are:
M-F 8:30am to 7pm ET
Sat-Sun 10am-2pm ET
