Recently I renamed some sensors around the smhouse, and although they are named correctly in the panel, it is not updated in the alarm monitoring company. Any help is appreciated.
Thanks
Thanks
I have sent a command to update Alarm.com with all of the sensor names in your panel it should take a few minutes to update.
Typically, running a cell test can sync the names as well.
Additionally, from the device list in settings on Alarm.com you can rename any sensors this way as well.
Awesome Tylet, thank you for the help!
