Can you guys check on my z-wave network. I have two temp sensors showing red lines in my advanced diag screen on my panel. They are working but showing red lines - please see pictures bellow.
I also have notice that on my web interface sometimes my “basement Sensor” has a “!” on it but it’s also working and iphone app does not have “!” at the same time.
Sensors currently in questions are:
Lucas Bedroom
guest Bedroom
Is it possible that two mention above shows in red because devices are in “sleep” cycle. I just check again and “lucas” room is green now but guest is red. It will never throw error in the little “surity” logo on the panel right corner.
Is there a difference from
Me running rediscovery on the panel compared to you guys sending that through adc?
Can you go on ADC and update all statuses real quick?
Lucas Bedroom
guest Bedroom
The Temperature Sensor is a wake-up device, which means it communicates less frequently than other Z-Wave devices in order to conserve battery power and increase longevity. Since the Temperature Sensor is dormant most of the time, it does not generally take part in Network Rediscoveries either.
Functionally they are the same, you can send the command yourself locally when needed.
