Are you using the included magnet or is it a different magnet from a pre-existing sensor? Also, when batteries were changed, you swapped both of the batteries inside yes?
You could always swap that sensor for a different DW10 in a different location in the home which has showed no false alarm issues. If the same one continues, it is an issue with the sensor. If the new one falses, it is an environmental issue.
