Up until 2 weeks ago, I had a system being monitored by Vector Security and was using the Alarm.com app to control my system remotely. I am now looking at Surety to self-monitor but want to make sure there won’t be any issues with connecting my system. I took the panel off and tried to verify the serial # but there is only one sticker inside with numbers and that serial # didn’t register when I tried to verify. Should I still go ahead and sign up for the plan? I would imagine it works since we were using Alarm.com before.
Thanks Jason! I could not locate the exact model I have but I was able to locate one similar. I checked the panel and located a 16 digit number which is not working in your system. There is nothing labeled IMEI. I found a serial # but it is a combination of 8 digits/characters. I’ve attached images of the info that I have from my system. Please let me know if I am missing something. Thanks.
That is a 2GIG GC2. Use the instructions for the GC2 at the link provided.
The IMEI is printed on the module, in the case of some modules, that is found on a sticker on the underside of the module. Click here for a video showing that.
If you have the installer code for the panel you can also find it in the UI under Installer Toolbox > Radio Status. (here it is labeled serial number, same number)
