Hi, happy to help!
I’m going to answer these two questions in reverse:
Will all my settings on alarm.com and the app stay the same? I have about 20 named zones setup (windows, doors, etc.), routines, users, etc. Will I need to redo them or will my alarm.com account just be migrated to managed by Surety?
Typically, buying a subscription from us and running through the setup steps in our website creates a brand new Alarm.com account. It requires an unregistered 4G Alarm.com module.
If you are moving from an existing system, this would mean that you would need to recreate users, notifications, and automation rules in Alarm.com. Your panel programming wouldn’t be affected. Sensor zones would remain the same on your panel.
That said, there is a transfer process available which would migrate your existing Alarm.com account to Surety. The caveat there is that it requires your current dealer to agree to the transfer and some do not support this. Note that a transfer can take a few business days to complete once the current dealer initiates the transfer.
If you would like to try to transfer, be sure to check with your Alarm.com provider to see if they would support a transfer and let us know! I can provide instruction on how to get started.
I’m being told I need to upgrade my cellular module from 3G to 4G LTE. Surety doesn’t sell the model I need. However, if I buy and install either an ATT or Verizon module and install myself, can Surety take that over?
Correct. By the end of 2022 3G cell modules will no longer be able to function, and there may be areas where signaling is impacted leading up to that date.
Because of the impending sunset date, Alarm.com has disallowed new 3G module activation since June 2019. Accounts cannot be created with 3G modules, so a 4G module would be needed.
Currently, if you are looking to transfer per above suggestion, you should still be able to transfer with your existing module.
This wouldn’t change the eventual need for a 4G module, and a 4G module will have better quality signaling anyway so I strongly urge replacing it sooner than later. But you could do that through our System Manager some time after completing the transfer if that’s the route you want to go.
