Tilt Sensor set up as window/door
I have a tilt sensor on a secondary garage that I do not use for normal entry/exit. When setting up the sensor on the panel, when selecting tilt, it only gives me the option of entry/exit when I want it to be more of a perimeter instant alarm if activated. I set it up as a door/window with code 13 Instant perimeter and it seems to do exactly what I want when it is tripped. Is there any reason I should stay away from this?
Thanks!
You’re exactly right, that should be fine. I guess the auto-learn feature just wants to assume all doors are entry doors. You’ve graduated past auto-learn into advanced security alarm guy status.
Awesome! Ill expect a certificate with my next shipment :wink: ha ha!
Have a great night :slight_smile:
