do i need to re-sync my thermostat to gain remote access through alarm.com app or something.
It does not seem to be responding to the schedule change if i change it online.
It looks like the schedule may have been just created. Did you just create the schedule? The schedule will not take effect until the next time shift where it would change from one temp to a different temp.
Sending the schedule will not overwrite the current manually set temp.
I had created a schedule the day i setup this new system a couple weeks ago.
It did not stick. So i just created another one today. I will wait for the next schedule change.
thanks,
nic
I had created a schedule the day i setup this new system a couple weeks ago. It did not stick.
I only see logs of the thermostat schedule being saved today, with no entries from when the system was first connected. Did it previously follow the schedule you set for a while and then fail, or do you mean it never worked at all?
