Thermostat not responsive to door sensor open rules
House has two thermostats. One is behaving as usual. The upstairs is no longer responding to ‘sensor left open energy saver’ automation rules. I’ve tried changing settings with the rule and repeatedly enabling/disabling, but it won’t shut off when we leave the windows or doors open any longer.
I also don’t believe it is responding correctly to my armed away schedule, but it does seem to follow our normal temperature schedule settings.
Any thoughts how to fix this?
Have you made any other changes to your Z-wave network? I would recommend running a network rediscovery to make sure the Z-wave network map is accurate and the device is using the best repeating route.
If you have already tried disabling and enabling the rule, and editing/resaving the rule, I would recommend deleting that thermostat from the panel, wait about 20 minutes, power cycle the thermostat then relearn it into the panel.
This worked. Thanks!
