I installed the alarm.com thermostat and trying to get recirc fan to work. Now reading around it looks like that only works when the heat/cool is off. I want recirc all the time (in between the heat running)
Is there a setting to get it to work?
Is there different thermostat that will work with alarm.com that has recirc?
It looks like Honeywell YTH8320ZW1007/U does.
It says it runs 35% “including any run time with the heating or cooling system”
Will it work with alarm.com and my 2gig panel?
Not currently on this Tstat.
That isn’t an officially compatible Tstat. I haven’t tried it myself, but generally with locks and Tstats, if official compatibility is not listed, it will have problems and likely will not function.
Off the top of my head I am uncertain on another Tstat with that feature locally. I’ll do some looking today.
