tyler
(Tyler G)
January 12, 2022, 3:58pm
5
General Information
Staying up to date with Firmware
Qolsys does a pretty good job of regularly updating the software for their panels. Firmware can be updated locally via wi-fi.
You can find steps on how to update the firmware, along with patch notes, in the below guide. Subscribing to the thread will allow you to be notified when new firmware inforamtion is added.
IQ PANEL 4 - 4.0.1 SOFTWARE UPDATE - RELEASE NOTES AND INSTRUCTIONS
Release Notes:
New Features:
• Improved flow for local Software Update via Panel Access Point, including QR code scanning to auto connect to the network
• New user interface changes to encourage Wi-Fi connectivity and to help panels stay connected over time to the network
• Added Panel configuration support in advance of the pending release for IQ WiFi 6
Fixes/Improvements:
• Fixed an issue in 4.0.0 related to S2 versions…
How to Test Your Alarm System with Surety
Why Test?
Whether your system is new or existing, testing your system is critical to verify that everything is functioning as you would expect.
This is an extremely important step in the setup process.
Find bad sensors before they cause an issue.
Make sure sensors are programmed correctly.
Discover possible physical installation issues.
Test Sensor Signaling:
Login to Alarm.com and navigate to the Activity page. Here you can see all signals Alarm.com receives from your panel.
[howtest-a…
