I have been telling people forever, if you have smoke alarms in your home, or smoke detectors tied to your alarm system, you need to invest in the $12 can of aerosol smoke test, and test your smokes properly.
Failure to do so, may just cost you your life (or the life of your loved ones).
FYI Vivint uses 2GIG smokes:
Contrary to popular belief, using the test button on a smoke alarm/detector (and yes there is a difference between the two), does not tell you if it will actually work in the event of a fire.
Test your smokes at least every 6 months with aerosol smoke detector tester.
I gave up smoking 1.5 yrs ago and started vaping. I can assure you I now know that my smoke alarm works. Before I could figure out what was going off Alarm.com called me.
Now I open a window or 2 before I start my morning fix for nicotine
Just 1 more way to test the system and services… Thanks surety.
The critical thing is residue. I dunno about the vapor, but tobacco smoke for example will leave a residue on the detectors that may cause them to ultimately fail prematurely.
Whereas, on the other hand, the aerosol smoke testers do not leave a residue.
