How do the temperature sensors work; do they talk directly to the thermostat, or can they route communication through other z-wave devices?
I ask because I’m having new trouble with one of my sensors. The short of it is I had my system divided into zones with dampers, and this required a relocation of the thermostat with which the trouble sensor is associated. The sensor itself did not move and had been working without issue prior to the stat moving.
Best I can tell from the z-wave diagnostic screen on the panel, it is trying to communicate through either the panel or another z-wave device. If that is true, there really should be no issue because I have several other devices between the sensor and stat. I have run network rediscovery twice. I even added another z-wave light near the stat’s new location.
Another piece of information that might be helpful is that I originally had this issue with two sensors, but I did relocate one of the sensors and that appears to have resolved the issue. But I really don’t have the ability to relocate the other because of the configuration of the room.
Finally, I have the older sensor (the one that doesn’t read humidity). Wondering if the newer one has a stronger radio that might solve this issue.
