how to tamper a PowerG sensor
Tampering any sensor refers to opening and removing the cover. This will release the tamper switch.
Some select sensors will also have an optional rear tamper that is secured when the sensor is mounted.
If you are trying to learn in the sensor, many PowerG sensors have an onboard learn button which should be used.
Are you attempting to pair the sensor? Or just testing the tamper function? What model of sensor?
