I’ve been waiting years for someone to post this issue.
Although I’m still laughing about your statement “I know I’m not the first to have this problem.”, because you’re not.
However, I predict you won’t be the last, although I’ll be thrilled if a solution is discovered.
I experienced the same problem many years ago when converting from an ADT system to Qolsys. I didn’t have service with Surety at that time so I contacted Qolsys. They had zero interest in assisting. And that was when they were an independent company with motivation to succeed.
Environment:
Qolsys 16-F hardwire
Qolsys panel 2
lots of wired sensors from original ADT system
a few wireless sensors added in recent years
some wireless smoke detectors not linked to Qolsys.
All wireless devices function fine.
All wired devices exhibit the problems you described.
Homeowner is the ham and a very senior citizen.
I’m the “attic boy” and have had that assignment for many decades.
I’m also the “roof guy” when a hurricane approaches.
etc etc,
However I’m not an electronics guy or a ham.
Attempted fixes (from memory):
We tried various ferrite and choke experiments, all of which had no effect.
Installed new alarm wire with shielding, did various experiments, again all with no effect.
shield to known earth ground
shield to ground on 16-F circuit board
shield back to transmitter and related equipment
Finally concluded the problem was the RF directly entering the 16-F. (Again I remind you I’m not a RF or electronics person.)
Our resolution was to use a DPDT relay (plus switches and led status) to remove power (both wall and battery) from the 16-F while hamming.
Of course this requires manual operation by the ham. In my situation the ham is likely older than anyone you know, so his remembering has become a problem. To assist with memory we also added a wire from the relay back to contacts on the panel-2 and created an automation rule when the 16-F has been powered down for an extended period. (Since you have a panel-4 you would need a wireless sensor with auxiliary wired inputs.)
A couple years ago I asked Surety about an automation rule of “AND”, ie when sensor1 AND sensor2 are triggered then take an action. (All existing rules are based on “OR” logic.) Surety forwarded the suggestion to ADC and it probably sits in a similar folder as your inquiry. I assume that folder is labeled “When Pigs Fly”
