Hi there. My qolsys 2 panel is set to announce with chime and voice when our front door or back door is opened. It has suddenly stopped working today. I confirmed that the settings are correct to make the announcements and tested the sounds and the test sounds work fine. I also confirmed that when the door is open, the sensor is showing as such immediately on the panel. I have also done a reboot of the panel. Any other tips to try? Thanks so much.
Is it just those two specific zones where announcements aren’t working or is it all sensors?
If you update firmware to the latest is there a change?
Thank you Jason. I didn’t realize I had a firmware update available. I installed it and it appears to have resolved the issue!
