Is this the reason why cellular tests are failing on my panel but dual path test are passing. Because my panel has an alert that cellular is not connected even though my panel shows it has 4/5 bars
Yes that is likely, However, pings the module are currently successful, indicate the system is communicating across cellular as well.
Yes, I did a reboot and that seemed to fix the issue
