Last night around 9 pm ET, I received one alert of a “loss of supervision” for one sensor and I figured, oh no big deal, probably the battery, then I started getting many more alerts, basically cascading failures as each sensor started throwing an alert. In total the following sensors all threw “loss of supervision” alerts. At that point, it was inconceivable that all sensor batteries went weak/dead within 11-25 minutes of each other.
Back door-malfunction
Front door - malfunction
Garage door - malfunction
Motion sensor - malfunction
Flood sensor - malfunction
CO2 detector - malfunction
I have two energy monitors and one Alarm.com thermostat and those continue to operate.
Could a tech kindly remote into my system to see what is going on here?
Ok Jason, that worked. Everything is back online now. Let’s see how stable it remains. Is there anything you can access remotely in terms of failure logs etc?
Jason: Walk test, 5 out of 6 sensors responded ok. The only one I couldn’t check was in the attic, I’ll get to that later today. We had one “quiet” night yesterday with no loss of supervision alarms, will continue to monitor it, if it happens again, I’m going to request an RMA for the transceiver.
