I bought a frontpoint system on ebay.
The control panel needs to be reset.
If this can be accomplished, can you monitor it?
Thanks
Thanks
Welcome to the forum!
Steps would be dependent on the make/model of the panel in question. However, the service provider mentioned utilizes Alarm.com so the panel would be compatible with our service. Which panel do you currently have?
Note that an unregistered, Alarm.com compatible cellular module is required to obtain service, you can check the status of your module here.
You can find more information on how our service works here.
Service can be purchased with, or without, 24/7 Central Station Monitoring via the previous link.
